I have somewhat of a problem with the wiring in my loft conversion which I need some advice on...
I've remodelled the room slightly which involved taking out some of the walls. During this I've found what look like 2 spurs. They come up through the 1st floor level ceiling at the exact same point and then take opposite paths around the loft room. One simply ends in a double socket and the other has a double socket that then leads on to a really ancient fused switch box (the type that looks like it would then have the flex from an appliance go into it).
I have no idea where the spurs originate from except that they are on the same Consumer Unit breaker as the 1st floor sockets. The cables are fairly securing seated in the loft floor/1st floor ceiling void aswell - so there is no way of jiggling the cable and having someone watch the ends at another socket.
My problem is that I need more than the way sockets on one of these spurs and the other socket is in completely the wrong location of the room. This is going to be a home office so really needs to have about 8 or so sockets for computer, portable and mobile phone charging, Monitor, printer, Broadband router, etc.
I beleive that the regulations for spurs is that they mustn't provide any more than 1 double socket - so this fused switch box presumably needs to come off ideally and I shouldn't really add anymore sockets to the spur where my desk will be ?!?!?
Or... is there simply a limit to the load which is permitted from a spur? If so, since most of my items will be smallish load (phone chargers... 350mA, Laptop charger... 300W Max, etc.) would I be able to get away without having to rip down ceilings and stuff to put in a new ring circuit.
ANy advice much appreciated.
