Loft Conversion (Storage) - Beams Deep Enough?
17 Jul 2014
London
Hi everyone
Have a typical redrow type house (90's build).
Since removing the water tanks from the loft, I want to board it to use as storage (about 40sqm total brick to brick / 30sqm usable)
Details:
It's a duo/fink truss build.
The bottom chords are 95mm x 35mm, spaced about 55cm
The webs are 75mm x 35mm.
Doing the build is no problem, however I am unsure about whether the bottom chords are thick enough use, or whether I should place some decent sized beams across them?
I was considering telebeam (used in previous house), but decided it's above and beyond what's probably needed, and started to look at these wickes loft legs:
Or the LoftZone kit:
They look roughly the same (although the LoftZone has cross beams), is there much real difference between them on a day to day use?
Will use standard tongue and groove loft boards on each
Any comments appreciated on the beam depth!
