The house I've moved into has about 100mm loft wool inbetween joists and is boarded out above this. I'd like to improve the insulation as I believe 100mm isn't enough.
Can I lay Kingspan directly on the boards or is this a prepostorous idea? I'm totally new to this and would be grateful for some help. I would like to improve the loft insulation without wool etc if possible but not sure how to go about doing it. Thanks!
