- Joined
- 7 Aug 2018
- Messages
- 6
- Reaction score
- 0
- Country
Hi all,
I have just moved in to a property and am a little confused with some wiring that I have found. So there is a 20amp circuit on the box labelled "Water heater". Turning it off shows that the fridge in the utility room goes off, one socket in the smallest bedroom, the loft light and the shaver light/socket in the bathroom. Confused much.
So I went to the loft and found a wire coming in that goes in to a wall mount box with a fused front plate. coming out of that box is one 1.5 TAE to the shaver light down in the bathroom, and also a 1.5 TAE to the loft light via a switch in the loft - that drives two normal bare bulbs.
Now everything seems to work but I have never seen this kind of arrangement. I assume the circuit has been used as an easy way to add things away from the main rings.
What concerns me is the two things running off the one connection in the loft. Is that dangerous/fire risk territory?? If so I will probably lose the loft light off of it.
I hate moving in to someone else's lazy DIY jobs haha.
