Hi All,
First post!
Looking for some advice from the huge community here, please.
I have a set of structural engineers drawings (all approved by BR's) for installing a pair of steels in the loft in order to board it out to take full domestic loading. Each steel will be prefabricated in 3 non-equal sections in order to facilitate access.
The drawings specify that wood blocking is to be added to the web of the steel, on which the joist hangers are connected and, in turn, the joists themselves.
The method of fixing the wood blocking is essentially by bolting through the web of the steels however, I have a couple of questions regarding the exact method.
Q1) The 'through bolts' are specified in the drawing as "900 ctrs". Does this mean "exactly 900 ctrs" or "maximum 900 ctrs"? The reason is that it would be simpler for me to site the 'through bolts' at 600 ctrs, as this is the spacing of the existing joists and so I wouldn't be wrestling with their spacing or the mid-joist joints in the steels.
Q2) The steels have a (small) radius at the junction between the web and the lower flange. Should I raise the wood blocking slightly so that its lower face is at the top of the radius, thereby leaving a small gap between the upper face of the lower flange and the lower face of the wood blocking or, should I chamfer the inside lower edge of the wood blocking so that it can be fitted flush to both the web and the upper face of the lower flange without that radius interfering?
I suspect I may get replies suggesting that I contact the S/E however, I've had these plans for a year and a half and am only now getting around to getting on with the job! So, my relationship with the S/E company has pretty much elapsed and I'm sure there would be a (not insignificant) additional consultancy charge involved!
If someone here could add their expert opinion, that would be much appreciated!
Many thanks.
First post!
Many thanks.
