A
Alarm
You go and buy 2.4 meg and see what happens.
What I am saying is that every manufacturer with the cheaper kit uses 2.4. It gets bled over. Cameras are lost.
A tyical example you fit some cameras on it, another property does the same, you start recording their cameras. Seen it loads of times. Even on digital.
Are you confusing signal transmission and signal processing ?"Error Checksum" in the last segement of the signal is the reason. Google that, not gonna explain signal processing here...
Co-channel interference does happen with analogue. The stronger of the two signals will control the line and frame generation so that image is fixed in the screen while the image(s) on the weaker signal(s) will drift across the screen behind the stronger image.Analoge signal is like ur old TV, it will interfer like mad
But if the unwanted signal is stronger than the wanted signal then you are no longer "fine"."If the box say 2.4GHz digital (DSSS or Wifi) u are fine.
If you use 5.8Ghz you'll apparently need a licence from ofcom which costs £50 per year.
