I want to install a new shower in a bedroom. However, whilst the waste pipe run is straight (apart from bends to join to soil stack & shower tray), it is 8 metres away. I intend to use a HepVo antisiphonic trap at the shower.
Having looked at the Building regs, I am a little confused as to whether 8 metres is too long and also what the issues are ie pipe capacity to drain the shower sufficiently quickly or foul smells (or some other reason). Building regs for unvented branch connections state a maximum 4m for a 50mm pipe. However, as I am using a HepVo trap, I assume that this requirement is no longer applicable (now vented) and I can't find any Building Regs info on maximum pipe lengths for vented waste pipes.
I can get a (gradual) vertical drop of at least 200mm so I can easily achieve the required gradient of 1.8 to 9mm/m. I intend to use a 40mm waste but could use a 50mm waste if required.
Can anybody advise as to whether the above will work? I do have the alternative of installing a Sanishower macerator but don't really want to do this unless there is no alternative.
