I'm afraid you've missed the point in the above post. The comparison with a gas combi boiler was to show the large amount of power you require to provide instantaneous hot water demand, at a decent flow rate. This will be true for electric, or gas boilers.Thank you for coming back. Unfortunately there is no gas to the house . I can only get electric.
Just to break even on the cost of the boiler, over its lifetime, you would have to make savings of at least £30/month.The quote I've had is just over £4000 for the combi boiler . Would you or anyone be able to give any rough idea of what sort of saving per year I could make with if I were to go for this.
Forgive me I see your point now, thank you.I'm afraid you've missed the point in the above post. The comparison with a gas combi boiler was to show the large amount of power you require to provide instantaneous hot water demand at a decent flow rate. This will be true for electric or gas boilers.
With a highly insulated hot water tank, the relatively small immersion element can provide all the hot water you want, relatively efficiently.
I may be wrong, but this seems a big outlay for little gain.
The savings are zero.Would you or anyone be able to give any rough idea of what sort of saving per year I could make
Have you considered using oil or LPG for space heating? Don't know about LPG rates in UK but it would be cheaper than electricity for sure.If you only have electricity and want to reduce the cost by a meaningful amount then there are only a few realistic choices:
1 - Heat the house less, which means installing insulation or reducing the interior temperature.
2 - Find a much cheaper source of electricity such as a cheap overnight tariff or solar panels
3 - Use a heatpump for the space heating instead of a direct electric element.
Thank you. Though I don't believe that LPG would be possible due to not having the land to place the bulk LPG containerHave you considered using oil or LPG for space heating? Don't know about LPG rates in UK but it would be cheaper than electricity for sure.
That would involve an entirely new system and the £1000s would be better spent on a heatpump.oil or LPG
That would be an issue I just own a small bit of patio unless I can fix it to a wall. Also do you not need unfloor heating installed for this ? Has anyone here had a heat pump installed ?£7500 grant for air source heat pump if you have room for it...
You don't need UFH just oversized radiators. I think most require some outside space. Get some quotes?. Octopus are coming in fairly cheap.That would be an issue I just own a small bit of patio unless I can fix it to a wall. Also do you not need unfloor heating installed for this ? Has anyone here had a heat pump installed ?
No.Also do you not need unfloor heating installed for this ?
