Low Concrete Block Wall Foundation
23 Jan 2021
Southampton
I am looking to build a small garden wall using a standard dense block (215mm*4400mm*100mm), they will be laid 215mm face 5 high so the wall will be around 400mm-500mm high, length is approximately 2.5m.
The underlying soil is pretty stable and not been disturbed for a long time, the blocks can sit centrally on the foundation, what should I aim for with regards the concrete foundation dimensions?
Thanks,
Ant
The document you want is BRE Good Building Guide 27 which you may be able to find with googling. The LABC has some extracts and images discussed here:
