low voltage dowlighters
the first set of lights you show also come as a set of 4, i have them fixed to the back edge of the "table" i am sitting at now.
There is a way round the plug in psu problem, (apart from socket) get one that can be wired in instead
plugwash said:
yeah you plug the tranformer into a hidden socket controlled from a seperate switch
many people frown on putting 13A sockets on lighing cuircuits but i have done it in my own bedroom and i don't know of any regs prohibiting it
I am aware that you can pull a spur of a plug socket, a wire into a 3 amp Switched FCU and then onto the lights. But how would you pull a switch off a plug (in the same way?)
I've never seen the ones that you can wire in. Is the effect of these lights really good? Wouldn't mind some!!!! :LOL:
well you could put a socket on a lighting cuircuit as if it were a light fitting (though many sparkys dislike this i know of no reg that forbids is)
you could also wire the socket from a ring via a 20A dp switch or a fcu just like you do in the kitchen
Mmm Don't really understand that if i'm being honest. Do you mean for the FCU that being a switched FCU. So come of the ring to a Switched FCU (don't know what amp) and then from the switched FCU run the led wires into it? Or am i completely missing this one?
Thanks for your time
switched fcu--hidden socket---plug in transformer---lights
here
its not a good resolution (too much bandwidth) but it gives you an idea, the speed at which the colours change is variable, but i had it on fast to save time
Thanks bas, thanks breezer (like the wmv) seem to give off a real nice effect, think i'll get some.
Where do you get small transformers that would do 20w? How much of a difference does it make?
Between 2 rooms i need 15 lights (15 60w transformers (the lowest I see) are nearly £100)
If I am wiring 9 20w lights in my lounge, will a 250w transformer not be plenty?
Also, Will 9 20w micro downlighters be enough light for a room for 14'11" by 13"
Should I get 12? I dont want to start cutting holes for 9 then realise I need more.
However, I dont want it too look too much (less is more and all that)
Also, (so many questions)
When bulbs in my house blow, the RCD's seems to trip. Is there a problem that should be investigated before installing downlighters or can this just happen occaisionally? Also, any ideas whay may caise this. My bathroom bulb blew right out the holder, cut a clean circle at the top of the bulb, some sparks.
Thw wiring is exactly how it was when I moved in.
:) Ok I can get 15 60w transformers for £77 but I still think its a lot compared to £13 for one 250w. :confused:
Wont the 60w transformers all be underloaded if there is one for every light at 20w :?:
breezer said:
here
Brilliant!
Any idea if they have different coloured LEDs in them, or are those funky tuneable LEDs that output different colours from one diode?
LEDs will be a wonderful thing for home lighting. Especially on hot nights; sitting under all these halogens it's like a sauna in here. :LOL:
ban-all-sheds said:
What do you mean "pull a switch off a plug"?
http://www.maplin.co.uk/products/module.asp?moduleno=35945[/QUOTE]
I had a look at the big picture of this, and it is supplied via an IEC connector. Are there any rules against having a flex outlet where the flex coming out of it has a connector at the other end? I can't think of any saety reasons why it wouldn't be allowed (would rather have an IEC connector get pulled out than bare wires) but thought I would ask.
Suggestion: Ring main > 3A FCU spur > 5A (lighting) junction box > transformer or socket(if plug in transformer)
Take a switch cable from junction box to switch location and wire as if wiring a light from a junction box.
the only problem i can possibly see with wiring in a flex to a iec line conenctor is ip rating
domestic wiring stuff has to be ip4x iirc (protection against solid objects over 1.5mm iirc) and im not sure an iec line connector is (the line connectors are never shuttered and it depends a lot on exactly what mesurement they take as it is a rectangular slot)
having said that its definately no more unsafe wrigin one in than leaving it plugged into a socket
