- Joined
- 10 Feb 2020
- Messages
- 2
- Reaction score
- 0
- Country
We have an intermittent fault with our central heating system installed by British Gas, which we've had them out twice to try and fix but so far the issue keeps coming back!
Our CH/HW programmer is an Drayton LP722 which is set-up with times for the HW and CH to come on.
There is also Drayton Digistat+ wireless reciever wired into it for the thermostat downstairs.
The issue is, when the programmer hits time for CH, it will turn on and heat the radiators regardless of what the thermostat is at.
To test valves etc I took the thermostat up with me and turned it all the way down and then all the way up. The reciever would flash to show it got the signal and the "on" light would illuminate when the stat was turned up and would turn off when I turned it down.
However, regardless of what the stat said and the reciever showed, I would not hear the motorised valve change.
I then turned off the CH on the programmer and immediately would hear the valves move.
This leads me to believe that:
a) The stat and reciever are fine
b) The motorised valve is fine
c) The programmer is not reacting to the stat changes.
Any advice?
Any advice?
