Luke warm Domestic water
24 Oct 2006
Cambridgeshire
I have a baxi combi boiler, on HW+CH, pressure ok at 1.5bar when cold, CH works fine but Hot water is just lukewarm and never gets hot. Has anyone any suggestions thanks
What model Baxi is it?
Could be as simple as you are running the hot taps too fast.
Try closing them a bit and see if HW temp improves.
Other than that I would recommend getting an RGI in to check the max and min burner pressures
diverter valve sounds most likely suspect,but need more info - model will be a good start.
is it a constant flow of only warm water, have you tried turning the heating off and see what happens?
Following on from the above, does the ch flow get hot when only the HW taps are run?
