You won’t get that at the taps anyway, combi’s heat the cold main water to a certain temperature rise. Could be as suggested, but could also be the canoe filter on that boiler. It’s easy enough to carry out the suggested test
A really good plumber called today and the cartridge is knackered. We are going to replace the shower and some tiling as it’s a bit tired. Going for a bar mixer instead of existing concealed shower to make future maintenance easier. Hes capped the shower today so we have hot water at all the other taps now. It’s worked out at £500 parts, labour including the tiling which is som much better then the £2000 we were quoted. Thanks for everybodys comments and suggestions.
