Mac Book Pro
8 Nov 2006
London
Dear All
I have Mac Book Pro Mid 13 inch Mid 2012, 2.5Ghz Dual Core i5, Memory 8Gb 1600Ghz.. Switched it on this morning no Light at front flashing which it normally does on or off!!
Fan stays on continuously and the Charger not charging!! Hard Drive attempts to boot but stops. Anyone know what the problem maybe?
Many Thanks.
Most MBP issues seem to revolve around the logic board, if that's the case for you, it will be a scrap it job, I suspect. You can get them fixed, but it's 50/50 on it going again.
Turn off, turn on and hold shift down when you start it up, this disables software when it starts up, might work.
Or you could try holding down these keys:
alt(option), apple(command), p, r,
when trying to boot up, this should reset the laptop.
Good luck
Thank You Mr Chibs will certainly give it a go and report back.
