This may sound stupid and probably won't work if the doors are not plain doors but have you considered turning the doors round or upside down so the side where the MagLocks are fitted goes from outside to inside.
This a trick?This may sound stupid and probably won't work if the doors are not plain doors but have you considered turning the doors round or upside down so the side where the MagLocks are fitted goes from outside to inside.
And from the previous descriptions it seems the armature plates are mounted directly on to the door. - a small matter of a 13mm through hole each door to hide.No not a trick. It worked when the decorative hinges that went 3/4 of the way across the door were fitted to the wrong side of an expensive door. Turning it upside down put the hinges where they should be. The panelling was the same both sides and looked OK when upside down.
As mentioned above, not how you originally worded it.I thought this forum was meant to be here to offer advice and try to help people out? I asked a question and all i got is abused! Firstly, My engineer is not an apprentice alarm he has served his apprenticeship and is now in his second year of being an engineer and i have been doing this for more than 4 years i said i had been working for myself for 4 years. and for your info i have never fitted a mag on the wrong side either. My last job had 48 double mags and they were all fitted properly by the engineer in question. All mags are tubed in steel conduit within the wall but because i did not mention it means it must not have been??? And also i am fully insured. Just because i did not mention it does not mean im not insured. i know the exact costs of business, in fact i probaly have more insurance than most due to the size of the jobs we do.
I do not appreciate the comments saying that people like me give the trade a bad name, a mistake was made and i was looking for some regulatory advice! i am a prefered contractor for a number of the companys i work for and last year we received 4 letters of recommendation from clients i was working for. And these were not houses etc these were from site managers from large multi discipline installs, the last being a high school with 400 zones, 65 cameras, 56 door entry doors and nearly 1400 points on the fire alarm!
oh and i asked the compliance manager for the company i was working for to go out and look at our mistake and he said it would pass its audit with the locks on the reader side as it turns out on closer inspection they would not fit on the egress side as the type of door closers fitted on the door span the whole door and the mags would not have fitted on.
Anyway thanks to anyone who did try to help.
