micky p said:they have to be made of plastic due to being a magnet inside and also cheaper to make and they are smoother when made of plastic.
They could have been made of brass, it's just as magnetic as plastic.
Plastic is about 10 times cheaper to produce than alloy and about 20 times cheaper than brass which cannot be moulded and would have the be soldered or low temp brazed.
Agile said:My father worked for a year as a trainee draughtsman in a brass foundry and when I was about 13 he took me round the works. Crane & Co.
Agile said:15/4/2006 11.51 am "Powermax 155 Boiler"
My father had a PhD in electrical engineering but he still could not mend a boiler!
He would just have called someone from the Yellow Pages.
peca27 said:DIY'rs. I thought the point of this site was to offer advice for those who want to try some DIY or for those who want the professionals in (but do not want to get ripped off).
I can't remember that last time I read such a load of old bollocks.Agile said:Actually Oilman thats not so!
Brass is diamagnetic so would have a different effect to plastic which is paramagnetic. It is used in RF inductances to reduce the value as opposed to ferromagnetic materials which increase the inductance.
Plastic has little effect on a magnetic field whereas brass has a negative susceptibility.
Yes it does.peca27 said:.......the last time i checked that's how forum's work.
That doesn't mean u can write what u want.......
The choice is yours - that's the beauty of it being a forum.if someone insults u are u just gona ignore it?
Its important the its fitted on the return so it can pick up magnetic debris from the rads.
As long as its after the last rad it does not matter where on the pipe.
It will work in any orientation as long as you can manage cleaning it and spilling its contents.
The diverter failure on your model was due to a faulty design and not because of dirt.
The magnaclean is primarily to prevent the plate HE getting blocked.
Tony
