In one way nothing, in another way everything.Very odd. What has that to do with this thread?
Which 100kW hex's have you used for that, BB?
Not quick enough...
Or you could try this
www.sentinel-solutions.net/en/waterproducts/systemfilter[/QUOTE]
Thanks for that. Now to find one that is cheap enough.
It is clear you are intimidated by my knowledge.
You put it down to what you like.
That is what it is. You show no constructive views, only take matters to personal levels and are quite a negative person. Maybe you were not chastised as a child![]()
The new Senitel filter looks good. A bit pricey though.
There is more than one - which did you use?The Swep, the same used on the Gledhills.Which 100kW hex's have you used for that, BB?
There is more than one type of yawn - which did you do?Yawn!
Yawn!
That's exactly what a bullsh*tting charlatan would say (especially if they said it in the form of a rap).A plate plate exchanger is a is a plate heat exchanger.
And I'm still not really sure if the government should legalise DIY gas work, or leave it illegal, like it is now. What do you think, Bigsystems?
When it doesn't have usable connections, or methods of support. Most combi ones wouldn't be any good.When is a 100 kW plate heat X not a 100 kW plate heat X?
