- Joined
- 6 Dec 2018
- Messages
- 1
- Reaction score
- 0
- Country
Hi, I'm a householder not a pro.
Thanks for any thoughts.
My wife and I had issues with our Worcester boiler system losing pressure (I bled gas from rads - one in particular vented a lot, repeatedly - and repressurised).
I just located a significant leak at the Fernox TF1 magnetic filter. Both brass valve fittings, inlet below TF1 and outlet above, needed tightening - and even sprayed water when I flexed the TF1 lightly by hand!
I assume these joints had never been tightened enough by pro installer, maybe because TF1 Instructions say 'Special care should be taken not to over-tighten the valve flange nuts that connect to the Fernox TF1 inlet/outlet port'.
So I simply tightened them by what seemed to me a fair (not extreme) amount.
Separately,
I note the TF1 main body also can swivel a little on the TF1 inlet/outlet section, either side of vertical
(to tighten the two parts firmly together, main body leans 5 degrees or so to side).
Is this normal?
Separately,
Is this normal?
