Ditch the surge protector. Lots of leakage current, and they don't give much protection.
Can one actually get passive ('latching') plug-in RCD adaptors? - like many/most RCD sockets, they always seem to be activeIf the pond is suspect get, a LATCHING RCD that does not trip on power loss.
I certainly posses some but I haven't bought (or used) a plug-in RCD in years so I don't know if they are still available.Can one actually get passive ('latching') plug-in RCD adaptors?If the pond is suspect get, a LATCHING RCD that does not trip on power loss.
Looks like we will plan for a new panel at some point in the future as suggested.
In conjunction with splitting circuits and the use of RCBOs it probably will.A new 'panel' (consumer unit) will not fix this problem.
It obviously would not 'fix' the problem - but, as some of us have said, it certainly should help in localising the problem, which hopefully could then be identified and 'fixed'.In conjunction with splitting circuits and the use of RCBOs it probably will.A new 'panel' (consumer unit) will not fix this problem.
If you think that then the probable "fix" will be the OP getting rid of some of his PCs etc.It obviously would not 'fix' the problem - but, as some of us have said, it certainly should help in localising the problem, which hopefully could then be identified and 'fixed'.
What the OP wrote was actually rather ambiguous - it may welkl have been a 1960s CU and a (younger, separate) RCD. I lived with such an arrangement for a good while in the distant past.1960'S RCD ? It's tired
IF that is the source of the problem, then you're right. However, that is speculation. I was obviously thinking more of the situation in which there was an intermittent fault, in which case the splitting/RCBOs would help in diagnosis, but would not afford a 'fix'.... the problem is probably not one of something being faulty, it is probably one of the cumulative and inevitable leakage from the power supplies in all those devices. In which case splitting circuits and the use of RCBOs probably will fix the problem.
That sounds like a rhetorical questionShould we be suprised that neither of the so called electricians, when faced with a tripping RCD, did not carry out functionality tests on the device?
i had a mate who had a 1960's wylex board with a rcd main switch, it drove him mad until we tripped all the mcb's and went to the pub, came home an hour later and yes..... the rcd had tripped it was well due for the retirement home
There is the possibility that your RCD is particularly sensitive - shame he didn't rule that out.
