Mains Bonding
6 Aug 2009
Leicester
I have seen quite two different set up for mains bonding of gas and water pipes
1)all earth cables lead back to the consumer unit
2) all cables lead back to a dedicated earth block
What's the benefits if any of having a separate earth block over using a consumer unit? What is preferred?
No difference. You can either have an external Main Earthing Terminal or use the earth bar in your consumer unit as the Main Earthing Terminal
