For what it's worth, here's my thinking:
I always try and fit a dedicated circuit and put it on the non-protected side of the cu so it doesn't go off if the rcd trips.
i can see in this install, it is not feasible.
BA companies like to fit it to the lighting circuit because (for some reason) the teaching is to use the smallest denomination mcb/fuse.
But I think it is short sighted using the lighting because in my experience as a pro spark, the lighting is the circuit most likely to fail.
I would spur off a ring, using an unswitched spur with a 2 (or max 3 Amp fuse. ADE recommend 2A.
Most panels draw a max of 1A anyway so this is no problem.
Don't forget, to comply with the almost outmoded BS4737, the back-up battery must keep the panel up & running in the event of a power failure for at least 8 hours.
I have seen allsorts in my trade (which covers the NW), including so called reputable nacoss firms fitting crappy electrical supplies to panels.
The worst of these was in Manchester, where I found a highly respected firm having fitted a fused spur (13A) with flex (NO!!!!) and it was wired directly to the main tails in a n old Wylex board with a wooden back. Instead of letting the flex into the box, they had just screwed the cover back on, flattening the flex in the process. Unbelievable!
