- Joined
- 27 Jan 2008
- Messages
- 25,313
- Reaction score
- 2,959
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I first came across the maintenance free spring terminal in 1980, when working for a Dutch firm, by 2000 many panels were using maintenance free spring terminals and it seemed anything imported for Europe used them.
The vibration with any steel frame structure did result in screw terminals working loose, so it was an on going job to test terminals are tight, and it was included in the service schedule, however I have never seen a house serviced, even with an EICR I have not seen anything about checking screws for tightness.
So if the installation is not maintained, then it should be all or nothing, it does not matter if a sheet of plaster board needs removing to service the junction box, if even if the junction box is service mounted no one will ever check the terminals are tight.
But nearly every European control panel manufacturer makes a maintenance free version for the control cables, but every box I have opened the power cables still use screw terminals, so not really maintenance free, but reduced maintenance, one amp with a spring terminal is great, but as you go up in amps, service area of contact becomes important, so we move from the spring to the crimp.
So any box with cable restraint and crimp connectors is maintenance free, or when potted of course. I have used maintenance free cable joints using crimps all my working life, using epoxy lined shrink sleeve, and potted, although the old joints pre the shrink sleeve were around when I was an apprentice I never used them.
There seems to be an idea maintenance free is new, it is not, maybe not as old as the hills, but been around all my working life and now retired.
What has changed is type testing, when I started we did not need to look for BS 5733 or any other standard when using maintenance free joints. As @Risteard says if you change something with a type tested item then it loses its type tested status, so if you fit a non recommended door bell transformer into a consumer unit then it is no longer a consumer unit, it is just a distribution unit, I have seen people argue as such not covered by Part P, but that is really clutching at straws.
But it raises the question can or should we use non type tested equipment in the home? We saw so called socket protectors sold in nearly every supermarket, non had BS 1363 stamped on them, I would remove when I did an inspection and put in a carrier bag, and hand to some one on leaving for disposal, saying these do not comply with regulations, I would never bin them myself.
However I have seen the local council social services insist on their use, and although now banned in Welsh national health places they were at one time seen in every dentist and doctors waiting room.
So how important is type testing, and can we use non type tested components? I have used silicon sealant in a tube before now to make a cable joint, it takes a long time to completely go hard, but no water can get in and once hard it is better than original cable, same covering in silicon sealant then insulation tape, once sealant has gone off even if tape removed no access to live parts, there is no BS number for a DIY joint like that, but I knew where used it was safe.
Even a simple blue pre-insulated crimp is not to standard unless crimped with the crimp pliers supplied by the manufacturer of the crimp. Only GEC large steam turbines of all the firms I worked for calibrated the crimp pliers and insisted only one manufacturer of crimps used.
Let him without sin cast the first stone.
