Making a radiator tail for a drainoff
7 Dec 2007
I need to drain down CH system but there is drain valve at lowest point.I would like to make a radiator tail using a short length of copper with sevice valve in-line and solder the copper to female part of rad valve.
1. will this work ?
2.is there a better method of achieving a drain-down point?
I ought to emphasise that this will be a temporary measure and I will use a more permanent solution later eg a radiator valve with integrated drain-off valve
Where the copper goes up into the rad, instead of using a 90 degree bend or an elbow, use a tee, with a short length of copper on the open end of the tee, with a drain off valve soldered on?
Or get one of these
942767.37434c7dbfbaec6655.21103146
They are handy as you can just drain the rad as a draincock on the pipework drains the lot.
Or get one of these
Correct John, why mess about with bits of copper and T's, just buy a lockshield with built in drain off, some people like to make life hard for themselves :rolleyes: :rolleyes: :rolleyes:
I've heard these are unreliable and s****!
EVERY drain cockis unreliable and carp. But ugly home made stuff will be no better.
seco services Posted: Sat Jun 18, 2011 4:56 pm Post Subject:
I think you misunderstand, my friend. These draincocks are BEFORE the valve so drain the system, not just the rad.
You are thinking of these, 2nd image down:
http://www.plumbingsupplyservices.co.uk/acatalog/std_valves.html
