Guys, I'm quite keen to make my own vinyl storage unit, something along the lines of the Ikea Kallax idea, so essentially three 'cubes' wide by two height.
Essentially build a rectangular frame being about 700mm in height, 900/1000mm wide, split in half horizontally, then vertically a few times.
What I'm struggling with:
1. How to join bits of wood which are less than say 35cm wide for the frame.
...Dowels seems like something I'd perhaps mess up - I have a decent amount of space to work, but all hand held tools, and I believe accuracy would be paramount for dowels (perhaps I'm wrong!)
...support battens in each corner being say 20mm wide - a lot easier, but way uglier
2. The best way to do the divisions for maximum strength - for those who don't know vinyl is bloody heavy - with the Kallax you'd be looking to put around 18kg in each cube - so this unit I'm building would need to support about 50kg on each level
I think critical to all of this is the sort of wood I use really - using solid wood that's over 30cm wide seems tricky to find - most places seem to go by thinner bits you'd need to join - I was looking at say pine or spruce.
Attached is the end result I'd want - not precious about it looking exactly like that pic, just to give you an idea (oh and that;s about £400!)
Any thoughts/advice on this much appreciated! - I'm working with a fairly tight space in which I need to get quite a lot - the Kallax with its chunky frame, especially with a 2x1 and a 2x2 butted together takes up precious mms needed for a desk/speakers/sub etc!
Cheers guys
Cheers guys
