I
Igorian
I shouldn't worry about making it last longer cos it'll be out of date in 6 months
Igorian said:I shouldn't worry about making it last longer cos it'll be out of date in 6 months
You're right there! Mine sits here out of neccesity for space:Allenm said:Back to your original point, if you want to make it last, the best thing you can do is keep it well away from a carpeted floor! you would not believe the amount of fluff that can cover every single bit of your precious hardware. If you can't avoid the carpet, then invest in a tin of compressed air, and give the insides a good blast to clear out all the crud. Do this around once a month (more if the cat uses the warmth of the PSU as a bed!!).
You Flish GatAdamW said:pipme said:Apparently, 'Hibernate' creates a file a little larger than the total amount of memory in the computer ...
Well, I only have 900GB on which to write a file containing the contents of my 1.5GB RAM
ninebob said:Needless to say I attacked it with the hoover and will be opening it up to do the same monthly from now on!
Eddie M said:Hmm, compressed air, I'd be wary of this. Last time I tried it, I blew all the dust into the PSU, which promptly shorted out.
