You seem to have a very officious aunty!
Haha a bit OTT at times but she's lovely and quite the perfectionist who likes things up to date and in good nick, we're very similar in that sense. I think it was a good call here, the existing frame would not have passed any inspection due to the amount of serious faults on it and even if there was never an inspection it shouldn't be left in that condition for us or others.
Funny tenancy which requires the tenants to do heavy construction work within their tenancy.
There's no abuse of human right here as I'm not obliged to do it I'm happy to do it, it's in the blood.
I re-landscaped my mums garden last year, dug up a 15sqm path & patio of large 100mm think Yorkstone slabs, shifted 5tonnes of crap material out and 5tonnes of MOT-1, sand & cement in for sub-base and setting. When the 5t of new material came the buggers wouldn't crane it into the garden as it was against their policy and just dumped it at the kurb outside our flat. I ended up having to carry it one bag at a time through the building, downstairs, through the flat to a holding spot in the garden and then eventually shifted it again up the garden stairs and into the ground. Did this job on my Jack Jones in 8wks and shifted over 16t including slabs, machinery etc... I also raised the patio 150mm from the ground and installed a bespoke Wood Block X design running along the outer edge of the path & patio creating giant flower beds between the path & patio's back walls. Now this was heavy construction, well worth it though as the garden looks lovely, mums happy and it's now a spectacle in the line up from the neighbors windows rather than the jungle next door! I only wish it was like this growing up, I did enjoy the jungle but you can't beat a good family BBq when the suns out, which we couldn't do at home.
Anyway Thanks Tony you're a legend, shouldn't be a problem from here & I'll let you know whats lurking beneath the mystery muck soon!!!!
Nige F, I had high hopes for you! You threw out a few relevant points, one twice,
It looks like a solid crust of S**T
the existing manhole lid is a double seal jobbie - it just needs a couple of pounds (lbs) of manhole grease smeared around the edges - if you can still get it .
and it is a double seal old style lid that just needs grease.
But in all, all irrelevant to my cause and questions!!!
Maybe you should start a private conversation with Agile to get some pointers on how to answer questions properly
and then add some curiosity/banter!!!
