Masonry paint crazing ?
No, no cracks previously. It sounds like this is borderline acceptable for professional work, considering the render is difficult to paint. I believe they rollered it btw.
In my professional opinion, rolling such a heavily textured surface is not a good move.
The use of a roller would certainly explain the visible pin holes and cracks. A roller is unable to force paint in to the crevices, hence my previous mention of "stabbing" the paint in
It is however, at a guess, 4 to 10 times faster than a brush given that much of the rolling could be done using extension poles rather than having to climb a ladder and use a brush.
It may be worthwhile looking for paint cracks at the parameters of the wall, in short, the areas where they would have had to have used a brush for cutting in. If there are no cracks in the paint in those areas, then it increasing looks like the cracks are a function of the use of rollers.
The fact that the previous finish had no crack is encouraging though. I don't think the new paint will fail if the old paint is still protecting the cement work.
I assume that you still have some of the paint left over. Why not use a fairly stiff brush to apply a coat to a sample area. If no cracks, then ask them to come back and apply a final coat by hand.
I have no idea how much they charged you, but I wouldn't have (knowingly) left it like that. The cracks may not have visible when they left though.
You refer to the quality of finish as possibly being borderline. I think it is substandard. But again, I have no idea how much they charged you, nor do I know how long they spent painting the walls.
It was two guys charging 150 a day each. Not cheap?
I've had a reply from Dulux themselves saying it's caused by the walls not being sealed and the application being too thick.
Having been previously painted, the walls were already sealed.
I agree that the paint was probably too thick.
£300 per day for two men doesn't really mean much given that I don't know how large the job was or how long it took them.
If you are convinced that you paid the going rate rather than getting a cheap job, then perhaps do as I suggested, namely brushing a sample area yourself. Assuming that it doesn't crack you will be able to point it out to your decorators and ask why the paint they applied ended up cracking.
Not sure why the size of the job has any bearing in it but for reference it was £1200 total and it's a bungalow. They apparently took 4 days, or 8 man days.
