- Joined
- 31 Dec 2007
- Messages
- 109
- Reaction score
- 0
- Country
Could it be an armoured cable running from your existing consumer unit (may be joined to T&E somewhere close the CU if you cant see it) in the house, up under the floorboards then off outside to the garage or some sort of outbuilding?
Do you have any buildings external to the house that have power?
As its already been said its unlikely to be a DNO cable but its certainly possible, but if its a power cable then any decent spark should have been able to identify what it is and where it goes within reason.
All the best
Dan
done more investgation. I'll try and get a pic tomorrow, hopefully the chinese internet cafe will let me load it over lunchtime.
it seems to run above in the ceiling above the CU area, runs through one small front room (which is above CU area), through the landing and seems to drop at the beginning of the extension wall. The wall was taken out when the extension was built (downstairs and upstairs were both extended) so if the cable did run outside it must have had to have been moved at the time of the extension. The cable does not run in the floorboard under the new extension, it stops before the extension begins.
Near the back extension there was a old immersion heater which was removed ten years ago. I am hoping that either:
a) the cable supplied immersion heater and is obsolete.
b) if it was a mains cable it will have been disconnected at the time of the extension cause the internal wall was knocked down to extend both the first and second floor.
Cable is about 2 to 3 cm wide and quite slender.
Wil continue to investigate and report with pc hopefully.
