Master socket or not?
Hi thanks that's a great help
Thanks to all.
Does it matter which main grey wire goes to A and B in the junction box?
Cheers
If you have a volt meter measure the voltage of the pair and note the polarity of the 50 volts there
The positive side goes to A and the negative side to B
If they are reversed it will not prevent equipment that is approved for use on the UK telephone system from working. Some equipment that is not compliant to the BT standards will not work if A and B are reversed polarty.
Many thanks
That's sorted now using my millimeter just running the cm 1308 cable to where I need to now
Sorry multimeter not millimeter lol.
All sorted now, standard broadband is back a 6.90 mb now fastest it's ever been lol.
Changing to fast fibre now with plusnet.
Thanks a lot to all of you
