McAlpine Pan Connectors Query
28 Jul 2018
I'm going to attempt installing a new back to wall toilet soon and was hoping someone could advise me if it is possible to Connect the McAlpine MacFit MAC-1 straight connector to the MAC-8 90 degree connector using the Linking connector MACLINK.
MAC-1:
https://mcalpineplumbing.com/wc-connectors/macfit/mac-1c-straight-macfit-wc-connector
MAC-8:
https://mcalpineplumbing.com/wc-connectors/macfit/mac-8c-90deg-bend-macfit-wc-connector
MACLINK:
https://mcalpineplumbing.com/wc-connectors/macfit/maclink-linking-connector-macfit
Ian
That’s how it’s usually done. Any reason you need to use a straight and bent pan connector?
Yes you can. But you could just use a WC-CON3 to omit the Mac-1 and the Maclink.
Thanks for the response. So the WC-CON3 can also be cut to a shorter length?
Yes, its just a piece of plastic pipe so you can cut it to any length you want.
I did it the way you originally proposed after a mcalpine flexi leaked but then realised i could have got away with one less part.
