Hi all, hope you can shed some light on an odd problem a friend of mine is having.
The CU is an older one from Hager, main switch and MCBs, no RCD, with an isolator switch before the CU. The CU was replaced a few years back (old one still had fuse wire) on the existing wiring, which must be pretty old but at least isn't tough rubber sheath. The problem circuit does the kitchen, hallway, boiler and a light on a spur protected by a 5A fuse.
Starting recently, the MCB trips after a random time, generally an hour or so, sometimes several hours. I cut all the power, unhooked the neutrals and used a multimeter to check L-E, N-E and L-N, which showed (as far as I know) no cable faults as very high resistance. I replaced the MCB with a spare of equal rating, no difference. I cut off the back end of the circuit which had the boiler, electric towel rail and spur light on it, no difference. The only appliance I didn't unplug fully was a dishwasher, because the morons who did her kitchen have blocked it in pretty good, but it wasn't turned on.
That's as far as my amateur diyer knowledge takes me, what could be causing a randomly timed trip and how would the more knowledgable go about finding out?
