A
Alarm
Go read the Yale manual.
JohnD said himself. He is not an engineer (sec systems), he just happens yo have one.JohnD said it was possible, until I hear a reply from yaleguy regarding this issue I will keep on asking:
How do I make the yale keyfob HSA6060 disarm the alarm without the need to set off the entry timer?
well, I know I've got one set like that, though I can't find it in the instructions. I've used both 6400 and 3800. I am not at the house now. I will see if I can find the setting in a menu when I am next there.
Hi Chunky - I actually go by the manual on this one I am afraid.
The reason the manual and system require the entry door to be opened before the fob will disarm the system is as some sort of proof that the person using the fob has authority to do so.
Imagine you do manage to set up the fob so it will arm and disarm without the entry countdown being active. What this would mean is if you drop your fob in your garden getting into your car perhaps or it falls out of your pocket or even someone visiting the house takes it they would be able to disarm your alarm simply by pressing the key.
The reason the system requires the opening and activation of the door/entry sensor is that acts as some form of authorisation of the user ie if they are coming through the front door they must have a key therefore they can disarm the system.
Is your gran unable to use either the remote keypad or the control panel itself?
One thing I try to get people to do wherever possible is add a pir in the hallway as an entry device.
This means that as someone comes downstairs they trigger the control panel countdown without opening the entry door. The control panel then starts counting down and this does two things
1. It allows you to then use the fob to unset the alarm and
2. If you don't have a fob it reminds you the alarm is set and reminds you to unset the system before you walk into your lounge set off the alarm and annoy your neighbours.
Hope this helps.
From the Yale manual, and TECH as I asked them.
The keyfob only will only disarm the system during
entry time after an entry or away entry door/
window contact or PIR has been triggered.
