I can confirm this is a good way to test your mains - I have 4 bar ( new house ish) and I can squirt my garden hose 40 Meters in the air........
If it's an open ended hose the water will just run out. If you then squeeze the open end, the water will squirt much higher. Hence gasmans rolling eyes.I can confirm this is a good way to test your mains - I have 4 bar ( new house ish) and I can squirt my garden hose 40 Meters in the air........
Indeed, hence my wink and laughing smiley when I posted itIf it's an open ended hose the water will just run out. If you then squeeze the open end, the water will squirt much higher. Hence gasmans rolling eyes.I can confirm this is a good way to test your mains - I have 4 bar ( new house ish) and I can squirt my garden hose 40 Meters in the air........
Please stop spamming the forum with silly advice or I will remove you from it.
He forgot to review his own posts - apart from some obsession having a dig at me, there are a couple of useful posts in his history over the last month, and the rest are as follows (check his post profile yourselves if you like, I got bored after 5 minutes):Please stop spamming the forum with silly advice or I will remove you from it.
Did you forget to press the MOD button when you posted?..................
Its forces speak for very hot
You must be wrong, these boilers do not break down, ever.
What does your installer say about this?
Installed loads of both and I'm with the 100 gang. Much more robust.
Don't hijack other peoples, posy your own you lazy get.....
wot a nosher
I'll give you a fiver, if you deliver
Think tony is getting confused......at his age though I'm not suprised
Why don't you do it?
That's handy, man
I'll mate with you in a minute
I'd have to catch him first though, in a benny hill style chase
