There's the properties of the methane contained in Fido's f@rts to contend with too!!
There's not really any such thing as a U-value for a room. A U-value is the amount of heat lost through one square metre of a given component. A room would have at least 5 components: the ceiling, the walls, the floor the window and the door, and all these would have different U-values. Combining the U-values together does not produce one overall U-value.
you are right, what people talk about as u value of a room is actually the heat loss of the room (worked out by calculating the different u values for every m2 of material in the room, taking into account the use of the room and the temp through the wall from the room as well)
To find actual U value . . .. .
Set weather to maintain constant temperature outside . . Very difficult
Set heating to maintain a constant temperature inside the room.
Close doors and windows, remove dog and cat.
Measure energy used by heating, deduct portion used heating rest of house - difficult.
Measure area of walls, floor, ceilings
Measure temperature difference inside to outside (assumes it is the same for all walls - means you have to demolish the rest of the house and put the room on stilts or the temperature difference would vary by wall and wall to floor ).
The energy used to maintain a constant temperature over a set period will allow you to calculate the U value of the room.
Now if yo think about the difficulties of real life measurement you will understand why the theory is used.
And for everyone else that happened a year ago!For me, this topic is exhausted.
