Could any heating engineers offer me advice on the following please? So far I have had two advise and they totally contradicted one another!
Situation: I have a property currently laid out as two separate flats, each has a combi boiler. The property is gradually being turned back into one 5 bed 3 bath house - ultimately with a megaflo or other unvented cylinder and a system boiler.
It is a bit of a non-standard situation because we are living in one or other of the flats throughtout, and the renovation is happening in stages, with the new system boiler going in the brand new kitchen extension, which is not scheduled until next year. Until then, I need to keep things running off the combis.
The cylinder however is to be situated on the first floor, in the upper flat, which is being fully renovated now. I am trying to ensure that everything that needs to be done for a smooth transition to a system and cylinder is done now.
Engineer 1 says: Put in your megaflo now, attach it into your upstairs combi as a temporary measure, until the system boiler is put in next year when it can then be transfered over. This will allow us to test the new pipe runs with the cylinder. Also, you need to ensure there is a secondary return on your hot water put into the bathrooms now, going back to the cylinder.
Engineer 2 says: Don't bother with a megaflo now as it can't actually be connected into the combi for temporary use. Wait, and do the combi at the same time as putting in the system boiler. In terms of pipe runs, nothing extra is needed on the top two floors for it all to work with a system boiler and megaflo - no secondary hot return needed.
I realise that the timing of the installation of the megaflo is quite a subjective issue, so i'm not too worried about that (i'd be tempted to wait so as not to incur costs of doing some change overs twice) but i am baffled by the secondary return issue - which I need to sort out now whilst my fix fix in the top flat is happening.
Thank you to all offering their thoughts and i hope that the above is clear enough to give a decent idea as to what's going on!
