megaflo issues
24 Dec 2003
guys, need some advice
Got a megaflo system in the garage.. the discharge pipe keeps dripping cold water when the system is on and the pressure keeps dropping.
I have regenerated the air space in the cylinder but this seems to have made no difference . please help.
Every morning I have to clean up a big puddle of water from my garage!!
You MUST get a registered operator to work on a megaflow.
This IS NOT diy, even more than gas.
These things are DANGEROUS if not properly set up.
Ring someone lke the CITB in Kings Lynn who might be able to tell you a name of an operator in your area, if yellow pages can't help.
The fact that you have a puddle in your garage is cause for concern as you should never have this. There is either a fault with the installation, or a fault with the cylinder. PLEASE don't try to fix it yourself, the energy in a cylinder can take a house down, and it's happened.
Ask to see the operator's card before you let him work on it.
