Very fast reheat times are only required for special applications like gyms amd in your house a reheat time of 20-30 minutes is quite adequate.
In any case you probably only need about 15 kW or 18 kW boiler power and fitting a 33 kW because thats the maximum a cylinder can absorb would be very expensive and greatly lower the boiler efficiency in normal use.
Fitting a slightly larger cylinder like 300 li will ensure that reheat times are irrelevant in normal domestic use.
During installation work and when the boiler is out of service many installations rely on a 3kW immersion and it always surprises me just how little problem that seems to give.
In any case many installations use direct cylinders which are only heated by the electric element anyway.
Tony
Tony
