Ive had the condenser coolant water-solenoid fail on my WT945....
--Its the Pink solenoid of the pair near the back of machine, the coil should read around 3.6K ohm. Mine was O/C and therefore no water-flow so the condenser didnt extract the water/moisture from the re-circulating air and hot steamy clothes was the result....
The solenoid-coil itself can be replaced with care, it will extract off the plastic part of the valve.
--Its best just to replace the coil only--as that valve has a flow reducer with the valve and flows (at some nominal pressure) 0.25L/Min.
The coils of these solenoids appear pretty universal, I used one I rescued from a dead machine, it was even the same make coil, although wasn't pink, and its DC resistance was 4K, worked fine however....
Worth also checking the two small pipes from these two valves, as they can crack and leak, because they are fixed one end, and attached to the condenser on the drum that bounces around a bit when running.........
