menvier 9751 RESET ZONE
13 Jan 2016
I have a menvier 9751,after a false panic button alarm, code zone f1t zo8 has appeared,
can anyone advise how to reset
VOLVO
Yes no change,but have found the fuse which I will remove if all else fails
And what's that going to achieve ? Apart from run your battery down and start your external bell ringing
I don't mean for ever , if I lose power for just a minute or two it may loss the foult and reset
If you do not have anything positive to say say nothing,I am looking for help
What do you think the battery is there for? It is to maintain the integrity of the system in the event of a mains fail.
and as sparky said .... "And what's that going to achieve ? Apart from run your battery down and start your external bell ringing"
You ask for help then, go off on one, instead of reading and answering questions asked by others.
I would guess that you are new to alarm systems and don't know their workings very well.
Was this a 'self install' or one by an accredited company? If the latter they will need to be called out to 'sort you out' soon.
Many members here are full time alarm engineers, sparky and I are just two of them, well, I'm off to bed, hope you don't have the 'bell' going all night, you're on that way.
Tap the side of the PAB with your knuckles or a screwdriver handle to make sure that all the works have reset properly - PABs are almost never used and can fill with dust, then the buttons don't pop out fully. Do you have the engineers code? If so (and your 9751 is fairly new), enter 199 and check the resistance of Z08. It should be about 2k2 if it "normal" (reset) and about 6k8 it it's still active.
