The old man and I have been trying to learn the dark arts of soldering copper tube and fittings. We can make a water-tight joint but it looks messy and the solder doesn't get all the way round the joint. Where are we going wrong?
Plenty of Laco (flux), immaculate copper, not too much heat, just enough solder to make the joint (slightly more than pipe diameter). That was what I was taught and it has servered me well. There may be some Martian technique, but I am sure you'll know if there is
Cleaning the copper is most important; then an EVEN heat over the pipe and fitting. Remember the Solder will run towards the heat.
Wipe the joint off with a damp cloth when you are done.
I often give a wipe of flux during the process as it helps disperse the heat better/evenly. I don't care if it is an unneccesary thing to do - it works for me, and I do very well by it.
hey mate....its easy...the more you do it the more the easier it becomes...ive just finished plumbing in my entire bathroom and soldering copper pipes in the ceiling....only had 1 slight pinhole leak..which i reheated (TURNING THE WATER OFF - FIRST)...watch this video here: http://www.easy2diy.com/cm/easy/diy_ht_3d_index.asp?page_id=35749917
