When changing a CU, the Tails must be 25mm, the main bonding must be 16mm
No they don't!! They have to have a higher current carrying capacity than the main fuse, so if you have a 60A main fuse then you can use 16mm tails and 10mm main earth!!
However fitting 25mm tails is good practice
16mm tails maybe, but not a 10mm earth
