I have a Metrel Instaltest 61557 and am struggling to get it to display all the results following an Auto RCD test. After running through the whole sequence, the screen shows results from the sixth test. When I press the DISPLAY key it then shows the first.
According to the instructions (not the best translation) I should continue pressing the display key to scroll through the RCD test results in order. The problem is when I press DISPLAY again it starts flashing "Clear All Memory".
A mate has the Easitest 61557 which uses the DISPLAY key to scroll through the six tests. Anyone know this tester and what i'm doing wrong?
Cheers.
Cheers.
