keyplayer said:
Come to think of it, I got a nice nosh off a mademoiselle in the grandstand, so maybe you're right.
Well the French are famed for their cooking I suppose...
Not sure what racing rotaries rev to, but I believe the RX-7 in standard guise redlined around the 8000+ mark (pre variable valve timing piston engines
). Perhaps it revs higher because there aren't valves in such an engine.
The Honda S2000 worries me, redline at 9000rpm. That's just not right!
I would love to hear one of those being properly wound up.
Did a quick calculation: according to the internet the S2000 has a stroke of 84mm. Now, at 9000rpm a piston is completing 150 full up-and-down strokes every second. So it is travelling at:
150 * 84 * 2 (cos it is up AND down) = 25,200mm/sec = 25.2 m/sec = 56mph.
But what about the accelerations? Well, I believe the piston would be moving basically in simple harmonic motion (I'm sure that isn't entirely true, but its near enough). Bear in mind it is nearly 1am and I am knackered so I will probably get this totally wrong (this will be embarassing if I get it wrong, SHM is the physicists equivalent of the two-times table
Maximum acceleration at the ends of the stroke:
a = -(angular frequency)^2 * displacement.
So, our angular frequency is 2*pi*150 radians per second, = 942 rad/sec
a= 942^2 * 0.0042 = 3731 m/s^2
a = 380g... not as impressive as I thought it would be, certainly not at turbine impellor-tip accelerations. What does a piston weigh? Quite a force on the gudgeon pin!
