http://lmgtfy.com/?q=http%3A%2F%2Fwww.ehow.com%2Fhow_5636554_change-lamp-frigidaire-microwave.html
1) Is the meter too sensitive?
2) Is the mobile phone safe?
Even with the 'throwaway' culture which surrounds us, it would seem a bit excessive to have to replace a microwave (assuming it still works satisfactorily) just because a bulb/lamp had failed!When I microwave gets to this age, I think its just a case of you not bothering to replace the bulb, and get a new microwave at some point in the future.
Kind Regards, John
The timer granularity is 10s, which is fine in reality. Not so fine is that it won't let you set longer than 99m90s on the timer, which is often not enough when using the fan oven, but other than that I've got no complaints.
Looks like a case of 'snap'. We've had ours for a good few years, it having replaced a very similar one that did very many years of good service prior to that, and, like you I could certainly recommend it. One of the reasons we chose it was that, at least at the time, it seemed to have a larger cavity than most of the available alternatives. (apologies for all the reflections - it's not actually anything like as dirty as it looks {without flash, it looked even worse!}).But if for other reasons you do need a new one, I can recommend this:
