that does not preclude the possibility that nearly half of them may fail within the first few minutes of use
Only true if the 'better half' were to last almost the rated number of hours
Only true if the 'better half' were to last almost TWICE the rated number of hoursOnly true if the 'better half' were to last almost the rated number of hours
The 'better half' would all have to last no less than (not "almost") the stated average (median) lifetime.Only true if the 'better half' were to last almost the rated number of hours
NO, you're thinking of means, not medians - see what I've just written to HarryOnly true if the 'better half' were to last almost TWICE the rated number of hours
I hadn't seen #15NO, you're thinking of means, not medians - see what I've just written to Harry
Yep, with almost all manufactured products, very early failures (e.g. 'straight off the production line') are relatively common - hence the 'bathtub-shaped' failure curves one sees (high early failure rate, then a long period of low failure rate, eventually becoming an increasing rate of failure in 'old age'). That's as true of light bulbs as it is of most other things (indeed, even including animal and plant reproduction, not just manufactured goods!)_Once, in a lamp making factory, watched such lamps being made, the final stage was testing, where they powered up on a conveyor belt. They would remain powered for a minute or two, then a photocell would check they were still lit at the end. Any which were not, or were too bright, were rejected. The too bright ones, obviously with shorted turns in the coil.
I don't think you mean #14 (which was written by yourself), do you?I hadn't seen #14
dunno wot ya meenI don't think you mean #14 (which was written by yourself), do you?
dunno wot ya meen
Yes. I clean the lens every time I change the bulb, - so quite frequently! TBH, the lens doesn't get visibly dirty due to it's corner position and the fact that I don't roast meats or anything that tends to 'spit' fat.I assume you keep the lens clean?
Fortunately the oven housing unit was designed specifically for my particular oven. The unit is open at the rear of the oven and has a gap of maybe 4cm (?) x unit width that runs behind the kitchen unit/cupboard that sits above the oven before emerging at the top. However, my Neff oven seems to vent to the front, judging by the draught of warm air emerging from slots in the front face.The kitchen installer hadn't fitted the oven airflow vents in the units.
True but I suspect there's more to it. I'd be interested to know under what conditions the bulb manufacturer conducts lifespan testing. Ovens may be used at a variety of temperatures. Perhaps the tests are carried out in ovens set to a low temperature. For instance, I prove bread dough at 45C in my oven. Or maybe accelerated lifespan tests are employed where the results are open to (mis)interpretation.Indeed - and, as I often remind people, even 'worse' than that, since average lifespan quoted is invariably a median, not a mean - which means that, even if the average (median) life expectancy ins genuinely hundreds (or even thousands) of hours, that does not preclude the possibility that nearly half of them may fail within the first few minutes of use
You are so right. There are far too many soul-sapping time-wasting chores these days, so I'm with you. I'll never blow another oven lamp in my conventional fan oven again because I don't have one fitted.Lights in ovens and cooker hoods are for first time use only, once gone then never replace them. Life is too short to waste it on the lamps
All true.True but I suspect there's more to it. I'd be interested to know under what conditions the bulb manufacturer conducts lifespan testing. Ovens may be used at a variety of temperatures. Perhaps the tests are carried out in ovens set to a low temperature. For instance, I prove bread dough at 45C in my oven. Or maybe accelerated lifespan tests are employed where the results are open to (mis)interpretation.
Shame they cant make LED ones because I have 8 LEDs lighting up a 4m x3 m living room that added up are only just more than a single 15w that lights a 0.4mx0.3m oven space. Crazy
