Combi boiler Potterton Midas , Myson BF ( 1993 - ALAH336).
Problem,
HW works ok, but CH does not. Pilot is lit up but main burner does not light.
Observations:
- Programmer´s internal battery is gone. I disconnected the prog.
- The pilot light ( should be on all the time) goes off after a day or two.
- System has been shut off for 3 years.
- I purged the radiators.
- Only device calling for heat is the electromechanical clock. ( that i can see)
Troubleshooting guide instructs to check 240V at external supply, timer and external control fault.
Here is my question. Do I need to have a working programmer ( external control fault?) for signal or is the electromechanical clock enough for the HC. It saves me from buying one and testing it to see if this is the root cause. Thanks...
