Miele Dishwasher Inlet/drain fault - help needed
4 Jul 2004
Miele Model G1180vi
Approx 11 yrs old
Fault:
Toward the end of (almost) every cycle, the Inlet/Drain LED lights – continual beep-beep-beep (error) and the cycle stops.
1-2cm of (dirty) water left at bottom of machine.
Filter must be removed & the remaining water be manually decanted from the filter housing (recess).
Unit must be switched off and the program reset to re-attempt completion.
Occasionally the full cycle will complete successfully, but not always.
Checked:
Non-return ball valve located under drainage filter– no blockage – ball moves freely.
Pump impeller turns (not stuck or seized – no debris detected)
Waste pipe checked for blockages at sink trap connection – none detected.
Any suggestions, please ?
Help much appreciated!
Did you ever resolve this issue? I'm stuck with a similar issue.
At the beginning of the rinse cycle (sometimes at the beginning of the wash), the pump starts for a few seconds and the cuts out.
I suspect the pressure switch which I removed and found full of fat. I cleaned it as much as I could, but I'm still having the same issue.
No fault codes are showing.
Any thought warmly welcomed.
