Symptoms:
Program starts water fills washing goes on... then 7mins into the cycle the light comes on. everything stops
What I have done:
removed the base. No sump water, all dry inside. removed and cleaned all possible filters inside and the ball valve. Removed hoses blew through, no blockages. Refitted one end and blew through again. Checked for kinks etc, nothing, no loose connexions. turned the pump with finger, some resistance, but felt like the magnet, anyway it will drain fully at the start of the program.
refitted everything
Whats happening now: tried on a prewash cycle, each time the same, fills, then about 8 mins in washing normally then it stops, light flashes water in the bottom, undrained. If I set the dial to stop and restart the prewash it drains and refills and starts again, then cuts out after 6-8mins with the same light issue.
Any ideas whats wrong....
What I have done:
refitted everything
