Not that I wish to doubt Lucy Pringle, but I do believe she is talking out of her Sour cream and chive-flavoured posterior.
"If there aren't any elements in solution (having been extracted by homeopathic dilution) some water molecules may be looking for the electrons and would tend to pair up with any other water molecules that pre-existed in the solution, since they would be replacing such heavier molecules one by one as were separated in dilution.
Yes, THAT would explain it
That explains it all. The water molecules MUST have a memory. Damnit, for all these years we haven't realised this. Does this explain why when I take a pee, the water molecules I just passed then wish to pair up with molecules that pre-existed in my wee-wee solution, i.e. shoot back up inside me?
Wakelam also suggests that in Rey's article in the New Scientist, "his thermoluminescence test seemed to pick out loose bonding energy of water molecules at 170 deg. K. Because electrons were stripped off the sodium chloride and lithium chloride during the homeopathic dilution, these electrons could provide the ghost linkage to the other water molecules and therefore the peak at 170 deg.K was lower. As previously suggested this could be tested if the separated solute was positively charged.
Yes, OK. First point, there is no such thing as "deg. K". You can have degrees celsius, degrees fahrenheit, or Kelvin. But not degrees Kelvin. Just Kelvin. That would be like someone measuring current in "Coulomb Amps" or some other made-up unit. Now I have that pedantry out of the way, can I just point out that when you put sodium chloride (i.e. table salt) or lithium chloride (which I
think is used as an anti-depressant) in solution, then yes, you do end up with a solution ions. No, you do not end up with a net positive charge.
Yes, and my theory about chocolate-flavoured monkeys could be tested if a bunch of them flew out of my ass! But on the day that happens, Mr Liu C. Fur will be ice-skating to work.
Despite great strides in medicine, physics, chemistry and biology, water and its behaviour still remains a mystery.
You should try talking to some scientists, the behaviour of water isn't a mystery to them. Why does water expand when frozen? Because it happens to form hexagonal crystals when it freezes. Whereas in liquid water the molecules can flow freely over one another (there is no long-range order), in ice the molecules are held rigidly at a set distance (depending on temperature). It just so happens that ice has a greater amount of space between the molecules as liquid water. Durrr.
The boiling point, melting point and heat conducting abilities are far higher than other substances an it takes more energy to boil a pint of water than any other liquid.
Boiling point water = 100 deg C
Boiling point aluminium = 2467 dec C
Melting point water = 0 deg C
Melting point aluminium = 660 deg C
Relative thermal conductivity water = 1
Relative thermal conductivity aluminium = 400
I'm not even starting on the "it takes more energy to boil a pint of water than any other liquid" comment, because it makes no sense. Many chemicals are a liquid at some temperature or other, and she makes no mention of what temperature she starts the boiling process at. If it is boiling water from 0 deg C, or boiling a metal from 0 deg C, guess which takes more energy... Hint: the element in your kettle doesn't even go so far as to turn into a liquid!
Now, I don't want to cast doubts on the scientific reputation of Lucy Pringle, after all she is a keen crop-circle enthusiast and a member of the British Society of Dowsers.
