My electrician has issued a MINOR ELECTRICAL INSTALLATION MULTIPLE WORKS CERTIFICATE.
P1 is completed as expected, the Serial No. of his test instrument filled in, but on P2, SCHEDULE OF CIRCUIT DETAILS AND TEST RESULTS is blank.
The property is an HMO, 2x existing radials from the CU go out to 2 of the rooms, the works involved installing 2x new Electricity Top Up Meters next to the CU, across these radials, a polarity test performed with a socket tester. A straight forward job.
The Radials were tested and certified last year on installation - (and then BC Completion Certs provided), with the SCHEDULE OF CIRCUIT DETAILS AND TEST RESULTS completed fully then with all tests done, does that certificate cover the cable circuits as they are now, and so the Minor Works certificates P2 does not need to be completed for these circuits, ie tests not required ?
Is this Non Notifiable work, and does not require a Certificate ?
https://www.diynot.com/diy/threads/minor-work-certificate.479035/page-2#post-3862551
